how to combine upload with image cropper in umbraco 4.7.1.1?
hi
i have a image cropper and upload now what i need is in place of adding alias of upload , directly upload is with the image cropper how to do it in umbraco 4.7.1.1?
Perhaps you should consider having a look at the cropup package, which let's you define all the crops you could fancy so you can just reference the crops of the image you need.
hi
Hi Siva
Hope this helps.
