  • siva kumar 120 posts 209 karma points
    Feb 25, 2013 @ 14:53
    siva kumar
    on server css not applying but in webmatrix it is working how to solve this problem in umbraco 4.7.1.1?
    hi in local through webmatix umbraco.aspx  heading color is chnaged but  in real server not changing  the colour how to solve it ?
    Feb 25, 2013 @ 18:56
    Hi Siva
    How do you reference your CSS files in your master templates? Are they referenced relatively or absolutely? And are you sure that the CSS files have been deployed to the live environment?
    Feb 26, 2013 @ 13:55
    siva kumar
    hi jan
     yes i ma referencing in master template(umbraco.aspx)?the path is  "css/umbracogui.css ".they are deployed in live even not getting the output how to solve this issue?
    Feb 26, 2013 @ 21:23
    Hi Siva
    Ok, the above CSS is referenced relatively.
    Try adding a forward slag before "css" like this "/css/umbracogui.css" and see if that works.
    Hope this helps.
  • Charles Afford 1163 posts 1709 karma points
    Feb 26, 2013 @ 22:29
    Charles Afford
    have you checked dev tools in chrome to see if the css file is being served?  If its not change the path :).  Charlie
