  • Mark 255 posts 612 karma points
    Mar 01, 2013 @ 23:39
    Mark
    Can't escape macro markup in rte / tinymce
    I've encountered two issues:
    1. Add a macro at the beginning of a rich text editor (tinymce). Then, after saving & publishing, go back in and try to insert a paragraph before it. It cannot be done.
    2. Add a macro at the beginning of a rich text editor (tinymce). Then, after saving & publishing, go back in and try to get the cursor outside the macro. It cannot be done.
    I know I can edit the html directly, but my clients wouldn't have a clue how to do this.
    Hopefully someone has a solution...
