custom404 not working properly in multilanguage website
I have a multilanguage website consisting of two country node (Israel, Japan) and each country node has several different language nodes. For instance the Israel country node has 3 languae nodes: Hebrew, English and Arabic.
In the backoffice, this looks like this:
for each language node I created a custom 404 page. This for instance is the custom 404 node for the Hebrew language:
In the umbracoSettings.config, I added these settings for my three cusom 404 pages:
<errors>
<!-- the id of the page that should be shown if the page is not found -->
<error404>
<errorPage culture="default">1725</errorPage>
<errorPage culture="ar-LB">1738</errorPage>
<errorPage culture="he-IL">1735</errorPage>
<errorPage culture="en-US">1725</errorPage>
</error404>
</errors>
Now here's the problem. When I enter a non-existing page in the browser, I always get the Hebrew custom 404 page. For instance when I enter "http://localhost/en/nonexsingpage" I get the Hebrew custom 404 page and not the English custom 404 page. When I enter http://localhost/ar/nonexistingpage I also get the Hebrew custom 404 page and not the Arabic custom 404 page.
Does someone knows why I always get the Hebrew custom 404 page, and not the other versions of custom 404 page.
This seems to be a source to great frustration. I've seen this before and must admit that I can't remember how we got i solved.
But something I have noticed is that sometimes it's required to recycle the app pool after setting up the error pages in the umbracoSettings.config - did you do that?
<errors>
<error404>
</error404>
</errors>
Thanks for your help,
Anthony
Hi Anthony
What version of IIS are you using?
Hi Jan,
I recycled the App_Pool, but no luck.
I'm using IIS 7.5
I also add the setting:
<httpErrors existingResponse="PassThrough" />
in web.config
Anthony
Hi Anthony
In the site where I know we had this problem we're not using the PassThrough stuff it seems.
Our httpErrors section look like this
<httpErrors errorMode="Custom">
<remove statusCode="404" subStatusCode="-1" />
<error statusCode="404" prefixLanguageFilePath="" path="/system/page-not-found.aspx" responseMode="ExecuteURL" />
</httpErrors>
Try setting the path to a page that does not exist and see what happens - the above page we refer does not exist in or outside of Umbraco.
Hi Anthony
Did you get any further with this issue?
Hi everybody,
We solved this issue via adding custom module that processes the errors and do redirect to the required page.
I think it's better than setting the path in the web.config.
Alex
Hi Jan,
Sorry for my late answer, been away a couple of days. To answer to your question, no, I wasn't able to solve this issue.
For some reason it's always the hebrew custom 404 page that shows up, even if I'm on the English content pages.
My settings in the umbracoSettings.config file look like this:
1740
Removing the HttpErrors setting in the web.config : didn't solve the case either.
I think I'll have to follow Alex' suggestion and implement a custom 404 handler.
I did this once for a website using the code that was provided by Sander:
http://stackoverflow.com/questions/6929304/add-custom-404-pages-in-umbraco-4-7
I've implemented this custom 404 handler, and it worked fine.
People interested in this solution might also be interested in how to implement your own 404 handler .
greetings,
Anthony
