  • Peter Alcock 113 posts 176 karma points
    Mar 04, 2013 @ 10:47
    Peter Alcock
    Javascript calendars using SSL
    Hi all,
    Having an issue regarding javascript calendars not functioning on pages using SSL certificate.
    The same page without the SSL the javascript datepickers work fine but as soon as i then add the SSL certificate onto the document type they stop working completely?
    Anyone have any ideas?
    Pete
    Mar 04, 2013 @ 11:27
    Mar 04, 2013 @ 11:48
    Peter Alcock
    Hi Rich,
    Had a look through that but didn't quite get how to do it for local js files, for external js files seems clear but can't get website js files to work still :S
    Anymore ideas or clues?
