  • mcgwest 23 posts 55 karma points
    Sep 02, 2009 @ 19:31
    mcgwest
    Error adding to SiteMapProvider
    I'm seeing this error pop up repeatedly in the audit log:
    Error adding to SiteMapProvider: System.Web.HttpException: 'http://calendar.unr.edu/calendar.aspx' is not a valid virtual path. at System.Web.Util.UrlPath.CheckValidVirtualPath(String path) at System.Web.Util.UrlPath.Combine(String appPath, String basepath, String relative) at System.Web.StaticSiteMapProvider.AddNode(SiteMapNode node, SiteMapNode parentNode) at umbraco.presentation.nodeFactory.UmbracoSiteMapProvider.loadNodes(String parentId, SiteMapNode parentNode)
    About the time these errors start showing up the search functionality in the UI stops working.
    Any ideas?
    Umbraco v4.0.2.1
    ASP.NET v2.0.50727
