  • Kyle Skrinak 272 posts 327 karma points
    Sep 02, 2009 @ 23:24
    Kyle Skrinak
    Help! Umbraco search broken by YAF update
    SERVER_SOFTWARE Microsoft-IIS/6.0
    Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433
    umbraco v4.0.2.1 (Assembly version: 1.0.3441.17657)
    All,
    We have a tabbed interface whereby our search results are categorized by a number of criteria, including a search that searched the integrated YAF forum. Now, after updating the YAF forum, the search is broken, rendering this error, found below the end of my problem statement.
    At a minimum, how do I disable YAF searching until I can fix this?
    Better, how do I correct this error?
    Much thanks!
    Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Source Error:
    Assembly Load Trace: The following information can be helpful to determine why the assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    Stack Trace:
    [FileNotFoundException: Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
    umbSearch.userControls.umbSearchTabbedResults.yafSearchResultCount() +0
    umbSearch.userControls.umbSearchTabbedResults.doSearch() +4705
    umbSearch.userControls.umbSearchTabbedResults.Page_Load(Object sender, EventArgs e) +269
    System.Web.UI.Control.OnLoad(EventArgs e) +99
    System.Web.UI.Control.LoadRecursive() +47
    System.Web.UI.Control.LoadRecursive() +131
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1436
    Sep 02, 2009 @ 23:39
    Dirk De Grave
    You'll probably have to re-compile your user controls against the latest yaf version as there seems to be a version conflict.
    I don't know if you can disable the forum search, as this is probably within the user controls' business logic, can you disable the search at all?
    Hope this helps.
    Regards,
    /Dirk
    Sep 02, 2009 @ 23:57
    Kyle Skrinak
    Yes, that is what I feared was the case. If I could swap in a "search under repair" message instead of calling the control until resolved, that would be awesome; however I would do that...
