SERVER_SOFTWARE Microsoft-IIS/6.0
Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433
umbraco v4.0.2.1 (Assembly version: 1.0.3441.17657)
All,
We have a tabbed interface whereby our search results are categorized by a number of criteria, including a search that searched the integrated YAF forum. Now, after updating the YAF forum, the search is broken, rendering this error, found below the end of my problem statement.
At a minimum, how do I disable YAF searching until I can fix this?
Better, how do I correct this error?
Much thanks!
Could not load file or assembly 'yaf, Version=1.9.1.0,
Culture=neutral, PublicKeyToken=null' or one of its dependencies. The
system cannot find the file specified.
Description: An
unhandled exception occurred during the execution of the current web
request. Please review the stack trace for more information about the
error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException:
Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral,
PublicKeyToken=null' or one of its dependencies. The system cannot find
the file specified.
Source Error:
An unhandled exception was generated during the execution of the
current web request. Information regarding the origin and location of
the exception can be identified using the exception stack trace below.
Assembly Load Trace:
The following information can be helpful to determine why the assembly
'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' could not
be loaded.
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.] umbSearch.userControls.umbSearchTabbedResults.yafSearchResultCount() +0 umbSearch.userControls.umbSearchTabbedResults.doSearch() +4705 umbSearch.userControls.umbSearchTabbedResults.Page_Load(Object sender, EventArgs e) +269 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +47 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1436
Yes, that is what I feared was the case. If I could swap in a "search under repair" message instead of calling the control until resolved, that would be awesome; however I would do that...
Help! Umbraco search broken by YAF update
All,
Much thanks!
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Assembly Load Trace: The following information can be helpful to determine why the assembly 'yaf, Version=1.9.1.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
Stack Trace:
You'll probably have to re-compile your user controls against the latest yaf version as there seems to be a version conflict.
I don't know if you can disable the forum search, as this is probably within the user controls' business logic, can you disable the search at all?
Hope this helps.
Regards,
/Dirk
