No content showing in backend after upgrade to 6.0.0
Hi There,
I just upgraded a site from 4.6.1 to 6.0.0 and now the only thing that displays in the content tab in the backend is a "Content" node. The whole tree has disappeared but the site actually still works it's just that I can't reach any of the content in the backend (see screenshot):
Media, Settings, Developer, etc. tabs all appear to be working as normal.
If I right-click on "Content" I get "Create", "Sort", "Republish Entire Site" and "Reload nodes":
Create gives me the expected create dialog box but I don't want to try creating anything yet until I know what's wrong.
Sort throws the following error
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Stack Trace:
umbraco.cms.businesslogic.CMSNode..ctor(IUmbracoEntity entity) +32
umbraco.cms.businesslogic.Content..ctor(IContentBase contentBase) +18
umbraco.cms.businesslogic.web.Document.<GetRootDocuments>b__1(IContent c) +38
System.Linq.WhereSelectEnumerableIterator`2.MoveNext() +151
System.Linq.Buffer`1..ctor(IEnumerable`1 source) +325
System.Linq.Enumerable.ToArray(IEnumerable`1 source) +78
umbraco.cms.businesslogic.web.Document.GetRootDocuments() +123
umbraco.cms.presentation.sort.OnPreRender(EventArgs e) +813
System.Web.UI.Control.PreRenderRecursiveInternal() +103
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2496
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
Republish works without error re-creating the umbraco.config file in the App_Data folder.
Reload nodes appears to be trying to, well, reload the nodes, but nothing shows up in the end.
Please help. Version is "Umbraco v6.0.0 (Assembly version: 1.0.4779.24222)"
I'm experiencing a similar problem. However I can see the content tree.
When trying to add content to a node (right click + create), I get following error in the create popup window.
Has enyone been able to fix the problem?
Source Error:
Stack Trace:
Hi There,
Source Error:
Stack Trace:
Regards,
Wole.
Source Error:
Stack Trace:
umbraco.cms.businesslogic.CMSNode..ctor(IUmbracoEntity entity) +42
umbraco.cms.businesslogic.web.DocumentType.b__1(IContentType x) +114
System.Linq.WhereSelectEnumerableIterator`2.MoveNext() +247
System.Linq.Buffer`1..ctor(IEnumerable`1 source) +487
System.Linq.d__0.MoveNext() +251
System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) +535
System.Linq.Enumerable.ToList(IEnumerable`1 source) +79
umbraco.cms.presentation.create.controls.content.Page_Load(Object sender, EventArgs e) +356
System.Web.UI.Control.LoadRecursive() +70
System.Web.UI.Control.LoadRecursive() +189
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3177
