  • Michael Hyldsgaard 64 posts 124 karma points
    Mar 09, 2013 @ 14:55
    Michael Hyldsgaard
    Nodes with upper case letters shows 404 error
    When I publish a document with the name "Test" the URL gives me an 404 error. The URL looks like this:
    http://domain/Test.aspx
    If I rename the document to "test" and publish the URL (which is now http://domain/test.aspx) works just fine.
    Any ideas what might be wrong? I've never seen this behaviour in an Umbraco installation.
  • Morten Christensen 596 posts 2773 karma points admin hq c-trib
    Mar 09, 2013 @ 16:54
    Morten Christensen
    Which version is this? The node name which is part of the url should be automatically set to lower case upon publishing, so curious as to how this could occur. Although I must admit I can't remember if there is a config setting for this.
    Mar 09, 2013 @ 17:13
    Michael Hyldsgaard
    Hi Morten.
    It's version 6.1.0 build 34...
    Mar 10, 2013 @ 17:28
    Morten Christensen
    Okay, I would suggest you report this on the issue tracker. It could be related to some of the routing stuff that Stephan has been working on, so it might be a good idea to at least run it by him. I believe he is back from vacation next week.
    - Morten
