Problem with Rich Text Editor and Inserting Images
When i click on 'Insert Picture' in a Rich Text Editor, the box that comes up displays a server error ... (see below)
This is using Umbraco 6.0.0 and 6.0.2
I wonder if I have maybe changed one of the pre-installed settings under Data-Types to do with images which would cause it to happen? Is there anything this depends upon?
Sorry it would not let me post the error as part of the message, so I am going to try again here
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\18c93782\4fd6b626\App_Web_uploadmediaimage.ascx.c3c18f9f.sdnbdoar.0.cs Line: 0
Stack Trace:
umbraco.cms.businesslogic.datatype.DataTypeDefinition.get_DataType() +242
umbraco.cms.businesslogic.datatype.DataTypeDefinition.<GetByDataTypeId>b__0(DataTypeDefinition x) +6
System.Linq.WhereArrayIterator`1.MoveNext() +49
umbraco.cms.businesslogic.datatype.DataTypeDefinition.GetByDataTypeId(Guid DataTypeId) +257
umbraco.controls.Images.UploadMediaImage..ctor() +70
ASP.umbraco_controls_images_uploadmediaimage_ascx..ctor() in c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\18c93782\4fd6b626\App_Web_uploadmediaimage.ascx.c3c18f9f.sdnbdoar.0.cs:0
ASP.umbraco_plugins_tinymce3_insertimage_aspx.__BuildControlMediaUploader() in e:\HostingSpaces\tjc\www.foodfortheflock.org\wwwroot\Umbraco\Plugins\Tinymce3\insertImage.aspx:187
ASP.umbraco_plugins_tinymce3_insertimage_aspx.__BuildControlpane_upload() in e:\HostingSpaces\tjc\www.foodfortheflock.org\wwwroot\Umbraco\Plugins\Tinymce3\insertImage.aspx:186
ASP.umbraco_plugins_tinymce3_insertimage_aspx.__BuildControlForm1() in e:\HostingSpaces\tjc\www.foodfortheflock.org\wwwroot\Umbraco\Plugins\Tinymce3\insertImage.aspx:150
ASP.umbraco_plugins_tinymce3_insertimage_aspx.__BuildControlTree(umbraco_plugins_tinymce3_insertimage_aspx __ctrl) in e:\HostingSpaces\tjc\www.foodfortheflock.org\wwwroot\Umbraco\Plugins\Tinymce3\insertImage.aspx:1
ASP.umbraco_plugins_tinymce3_insertimage_aspx.FrameworkInitialize() in c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\18c93782\4fd6b626\App_Web_insertimage.aspx.43b758d9.zne16lbf.0.cs:0
System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +48
System.Web.UI.Page.ProcessRequest() +72
System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +21
System.Web.UI.Page.ProcessRequest(HttpContext context) +58
ASP.umbraco_plugins_tinymce3_insertimage_aspx.ProcessRequest(HttpContext context) in c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\18c93782\4fd6b626\App_Web_insertimage.aspx.43b758d9.zne16lbf.0.cs:0
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +341
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18010
Thank-you for your response; unfortunately it did not fix it for me.
I have a 'Multiple Media Picker' data type which is brokem. It gives an error
on the data type screen. I am wondering if this is the root of my problem, though maybe it is unrelated.
- Cleared my temporary ASP.Net folder out (the folder mentioned in your stack trace).
- I was using TFS, which had locked my packages and umbraco config folder causing the uComponents install to fail. I checked these out of version control for edit, which fixed the issue (made them writeable).
I seem to have got it working again; I had 3 data types which were evidently corrupted, I deleted these and re-saved the RichTextEditor data type and suddenly it was right!
Just had this happen to me again for a different site... and have found this thread again!
Solution this time was as the other guys - looked through my Data Types and find/deleted any corrupt ones (e.g. those that show an error when I clicked them in the developer section). This solved the issue.
Thanks in advance for any help.
Source Error:
Stack Trace:
Do we have any solution of this type of problem? I am also getting the same issue,
Please help
Do you have uComponents installed? Installing the latest version appeared to fix the issue for me.
Tom
Just trying to think what else I did:
- Re-compiled my app in Visual Studio.
- Published all in Umbraco.
Thanks.
Thanks for your help.
Tom
Same for me it was the data type "Form Picker" from I think courrier.
It might help some people.
MrFlo
Paul
