Hello.I don't know if this is the appropriate sub-forum for this question so forgive me if I placed it wrong. Now the problem.I'm using a typekit font with my Umbraco website but it does not seem to work. When I contacted the Typsekit support I was told that the problem should be in this section of the code above my Doctype declaration:<form method="post" action="/" id="canvas">< div class="aspNetHidden">< input type="hidden" name="VIEWSTATE" id="VIEWSTATE" value="/wEPDwUENTM4MWRkYy+nh51OMbQPVudSbzzPNJpkn7EjL9odawRxZmy9ZwM=" />< /div><!DOCTYPE html>At first I thought it was the canvas mode that was enabled but turning it off did not solve the problem.
Any ideas on how to solve this? Thank you for your time.
Ok something really bad happen with my previous post so I will post again:
At first I thought it was the canvas mode that was enabled but turning it off did not solve the problem. I also edited a property in the UmbracoSettigns file to "true" but it did not work as intended:
<viewstateMoverModule enable = "true" />
The above code look weird since the form, that's inserted before the doctype declaration is not closed properly (I don't even want to consider why it's placed where it is!)...
But what does the whole source code of the rendered page look like? Where are you calling the javascript for the typekit font? And do you see any 404 errors or javascript error in the browser console of the browser?
<body> <div class="gridContainer clearfix"> <div id="Header"> <!-- this is the main navigation menu --> <ul><li><a href="/">Home</a></li><li><a href="/species.aspx">Species</a></li><li><a href="/wellbeing.aspx">Wellbeing</a></li><li><a href="/society.aspx">Society</a></li><li><a href="/blog.aspx">Blog</a></li><li><a href="/about-us-contact.aspx">About us & Contact</a></li></ul> </div>
<!-- These are the types of pages that will be displaying, only one at a time. --> <div id="Main">
</div> <!-- ------------------------------------------------------------------------- --> <div id="Footer"><p>This is the footer</p></div> </div> </body> </html> </form>
You can see there where the typsescript is being called. In chrome's javascript console I get no erro when I load the page. Also no errors on the browser. The pages works fine except for the font.
Rich:
I created the template called blank and I left it empty.
When I aff that to the home page URL i get this error:
Removed the form that was around the whole page and now it's working. But this means that i wont be able to use live editing. Anyway, thank you for the help.
Problem with typekit and Umbraco
Hello.I don't know if this is the appropriate sub-forum for this question so forgive me if I placed it wrong. Now the problem.I'm using a typekit font with my Umbraco website but it does not seem to work. When I contacted the Typsekit support I was told that the problem should be in this section of the code above my Doctype declaration:<form method="post" action="/" id="canvas">< div class="aspNetHidden">< input type="hidden" name="VIEWSTATE" id="VIEWSTATE" value="/wEPDwUENTM4MWRkYy+nh51OMbQPVudSbzzPNJpkn7EjL9odawRxZmy9ZwM=" />< /div><!DOCTYPE html>At first I thought it was the canvas mode that was enabled but turning it off did not solve the problem. Any ideas on how to solve this? Thank you for your time.
< input type="hidden" name="__VIEWSTATE" id="__VIEWSTATE" value="/wEPDwUENTM4MWRkYy+nh51OMbQPVudSbzzPNJpkn7EjL9odawRxZmy9ZwM=" />
< /div>
<!DOCTYPE html>
Joao
Looking forward to hearing more from you.
Create a new template called 'blank', leave it empty, then go to your site and add this to any url ?alttemplate=blank
You should see an empty page, likewise if you view source.
Let us know what you see.
Rich
Jan:
The form tag is closed later in the master page, I didn't show all of the source for convinience purposes. I'll paste now the source:
<div class="aspNetHidden">
<input type="hidden" name="__VIEWSTATE" id="__VIEWSTATE" value="/wEPDwUENTM4MWRkYy+nh51OMbQPVudSbzzPNJpkn7EjL9odawRxZmy9ZwM=" />
<!DOCTYPE html>
<html>
<head>
<!-- Dreamweaver -->
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link href="/css/boilerplate.css" rel="stylesheet" type="text/css">
<link href="/css/FluidGridLayout.css" rel="stylesheet" type="text/css">
<link rel="stylesheet" type="text/css" href="/css/style.css">
<script src="/scripts/respond.min.js"></script>
<!-- Fonts -------------------------------------------------->
(function() {
var config = {
kitId: 'low6bjj',
scriptTimeout: 3000
var h=document.getElementsByTagName("html")[0];h.className+=" wf-loading";var t=setTimeout(function(){h.className=h.className.replace(/(\s|^)wf-loading(\s|$)/g," ");h.className+=" wf-inactive"},config.scriptTimeout);var tk=document.createElement("script"),d=false;tk.src='//use.typekit.net/'+config.kitId+'.js';tk.type="text/javascript";tk.async="true";tk.onload=tk.onreadystatechange=function(){var a=this.readyState;if(d||a&&a!="complete"&&a!="loaded")return;d=true;clearTimeout(t);try{Typekit.load(config)}catch(b){}};var s=document.getElementsByTagName("script")[0];s.parentNode.insertBefore(tk,s)
</script>
<title>Eläintieto</title>
</head>
<body>
<div id="Header">
<div id="Main">
</body>
</html>
</form>
Rich:
What's the error you get when you turn off custom errors as described in the error message?
Rich
Here it is:
Just have your blank template as this :
<%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %>
No error now. I just get a blank page and the source is empty as well.
Hey,
Ok, it seems that something in your teamplates is adding the issues,I would back up your templates and start removing code and see where the error is.
Rich
