Hi, I am new to Umbraco and I am in the process of migrating a some existing websites across.
I have some aspx.cs files handling contact form emails etc. and want to use these in Umbraco to save starting again with those features. I have set up a template for the contact form and I dropped the associated aspx.cs file (just sends an email with the contact form content) into the Umbraco templates folder. But I am getting this error (it works fine outside of Umbraco):
Compilation Error
Description: An error occurred during the
compilation of a resource required to service this request. Please
review the following specific error details and modify your source code
appropriately.
Compiler Error Message: ASPNET: Make sure that the
class defined in this code file matches the 'inherits' attribute, and
that it extends the correct base class (e.g. Page or UserControl).
Source Error:
Line 5: using System.Web.UI.WebControls;
Line 6: using System.Net.Mail;
Line 7: public partial class SendMail : System.Web.UI.Page
Line 8: {
Line 9: protected void Btn_SendMail_Click(object sender, EventArgs e)
using System; using System.Collections.Generic; using System.Text; using System.Net; using System.Web.UI.WebControls; using System.Net.Mail; public partial class SendMail : System.Web.UI.Page { protected void Btn_SendMail_Click(object sender, EventArgs e) {
Don't use anything with .aspx in the filename with umbraco. Umbraco works with (nested) Masterpages. The template you've added in umbraco exists on the HDD as template_name.master. Rename your .aspx.cs page to .master.cs, correct the <%@ Master %> page directive:
CodeFile="SendMail.master.cs"
and change
into
public partial class SendMail : System.Web.UI.MasterPage
Importing aspx.cs files into Umbraco
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.Compiler Error Message: ASPNET: Make sure that the class defined in this code file matches the 'inherits' attribute, and that it extends the correct base class (e.g. Page or UserControl).
Source Error:
Line 5: using System.Web.UI.WebControls; Line 6: using System.Net.Mail; Line 7: public partial class SendMail : System.Web.UI.Page Line 8: { Line 9: protected void Btn_SendMail_Click(object sender, EventArgs e)In my Master template I have this:
<%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %>
In my Contact Page template I have:
<%@ Master Language="C#" MasterPageFile="~/masterpages/Master.master" AutoEventWireup="true" CodeFile="SendMail.aspx.cs" Inherits="SendMail" %>
My aspx.cs file:
using System;
using System.Text;
using System.Net;
Can I get this working as is in Umbraco or do I need to compile it and wrap in a Macro?
Many thanks if you can point me in the right direction?
Iain
and change
into
Thank you so much, that cured the problem and I have the first website up and running with Umbraco.
