Is there a possibility to duplicate users? Several times I had to create different users with the same rights. Duplicating users (and then adjust username and password) can save so much time.
Thanks for your post. But I would like that users have the same rights on specific nodes. I think your (nice) package only let you put a user to a usergroup(?).
Duplicating users
Hi Christiaan,
Have you checked my project http://our.umbraco.org/projects/backoffice-extensions/usergroup-permissions that allows you to set permissions on usergroup level then it's just a matter of assigning the member to the correct group.
Richard
Hi Richard,
Groet, Christiaan
