I'm looking for some help with creating a side navigation that contains anchor links to areas of a single page. These areas are individual feature sections of a features page, with the idea of the navigation being used to scroll between features.
Is this more of a structure question that a xslt question?
Ideally I would like the user to create an individual feature as a content node, under the Feature page, with the content of the sub nodes pulled into the parent page.
I raised a similar question before, and used the robot.txt file to hide the url's. Unfortunately, I cant use it this time, but this Umbraco Issue was raised. It has a status of Fixed, but im not sure how.
If you create a document type that has no template assigned to it I believe it should work as described in the request. However it will only work from v4.10+
Therefore you should be able to create anchors the way you describe above and not need to use a robots.txt to hide the url's.
However it seems to me that you would need to make sure that the created "anchors" under "Feature" are also identical with the anchor points in your rich text editor? Or how do you make sure the anchor points are created in the content?
Do you know if this has been carried onto v6? Im using v6.0.2. I seem to have a URL section within the node, even though I have no template applied. Is this what the request was asking for?
I was planning on using separate child nodes in the content tree as features. Hopefully using hthe node name, concatenated as the anchor link.
Anchor Navigation / Node Structure
- Feature
-- Individual Feature
Problem being that a node URL is created.
http://issues.umbraco.org/issue/U4-862
Hi Martin
Hi Jan,
