  • Pete 213 posts 285 karma points
    Mar 15, 2013 @ 13:10
    Pete
    Ogg and Webm Media file types
    Are these supported in the media section 4.11.04 ?
    I uploaded a couple but they don't appear as new nodes in media.
    Pete
    Mar 15, 2013 @ 20:55
    Hi Pete
    It's a matter of the webserver recognizing the mime type of the files.
    To make sure the webserver understand these file types you should add this in the web.config. You can see how it's done in this blogpost http://www.localwisdom.com/blog/2011/10/iis-7-web-config-change-for-html5-and-css3-mime-types/
    Hope this helps.
