  • René 327 posts 852 karma points
    Mar 17, 2013 @ 21:03
    René
    Preview does not work.
    I have a umbraco v 4.11.5 (Assembly version: 1.0.4807.33359)
    Database msSQL 2008 10.0.1600.22
    • When i create a new page the preview does not work.
    • When i save the page the previev does not work.
    • When i publish the page the previev works.
    • When i unpublish the page again the prewiev wont work
    Is this a bug, or am i missing something?
    I get this error when trying to preview an unpublished node.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
    Source Error:
    Stack Trace:
       umbraco.page.attrValue(XmlNode node, String attributeName) +10
       umbraco.page.populatePageData(XmlNode node) +157
       umbraco.page..ctor(XmlNode node) +156
       umbraco.presentation.templateControls.ItemRenderer.GetFieldContents(Item item) +209
       umbraco.presentation.templateControls.ItemRenderer.ParseMacros(Item item) +89
       umbraco.presentation.templateControls.Item.OnLoad(EventArgs e) +32
       System.Web.UI.Control.LoadRecursive() +70
       System.Web.UI.Control.LoadRecursive() +189
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3177
    Tanks, for this grest forum.
    René
    Mar 18, 2013 @ 13:04
    René
    Is there anyone who can come up with any ideas :-)
    René
  • ken bonovich 5 posts 25 karma points
    Mar 20, 2013 @ 17:22
    ken bonovich
    have you tried navigating to the page using the node id ie(http://yoursite/1234.aspx) ?
