uComponents_5.4.1 : Could not load type 'umbraco.editorControls
I installed uComponents_5.4.1 in Umbraco V 4.7 but I cannot open or load any
file now or even login to Umbraco as it generates the error below.
I also cannot uninstall the uComponents as I can’t login. Deleting the
uComponents Dlls from the bin folder doesn’t help either.
How do I get rid of the error or how to I completely remove uComponents
considering that I cannot login to Umbraco due to the error?
Error:
Could not load type
'umbraco.editorControls.ResourceExtensions' from assembly
'umbraco.editorControls, Version=1.0.4393.24047, Culture=neutral,
PublicKeyToken=null'.
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Exception Details: System.TypeLoadException: Could
not load type 'umbraco.editorControls.ResourceExtensions' from assembly
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Stack Trace:
[TypeLoadException: Could not load type 'umbraco.editorControls.ResourceExtensions' from assembly 'umbraco.editorControls, Version=1.0.4393.24047, Culture=neutral, PublicKeyToken=null'.]
uComponents.UI.uComponentsModule.IncludeScripts(Page page, Func`2 filter) +0
System.EventHandler.Invoke(Object sender, EventArgs e) +0
umbraco.BasePages.BasePage.OnLoad(EventArgs e) +19
System.Web.UI.Control.LoadRecursive() +71
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3064
I installed uComponents_5.4.1 in Umbraco V 4.7 but I cannot open or load any file now or even login to Umbraco as it generates the error below.
I also cannot uninstall the uComponents as I can’t login. Deleting the uComponents Dlls from the bin folder doesn’t help either.
How do I get rid of the error or how to I completely remove uComponents considering that I cannot login to Umbraco due to the error?
Error:
Exception Details: System.TypeLoadException: Could not load type 'umbraco.editorControls.ResourceExtensions' from assembly 'umbraco.editorControls, Version=1.0.4393.24047, Culture=neutral, PublicKeyToken=null'.
Source Error:
Hi John
It's probably because uComponents v5 is not supported in Umbraco 4.7 as you can see in this support matrix here http://ucomponents.org/compatibility/
Did you take a backup before installing?
Hi Jan
Thanks for the reply. I realised that after I had already installed it but I reverted to a backup and its working fine now. many thanks
Good to hear that it all did not get messed up! :)
Have a nice weekend.
