There are two ways you can do that. There is the "hard" way and the easy way. Must admit that I can't remember the "hard" way. But the easy way would be to make a user control and then in the datatype section use the "umbraco user control wrapper" datatype. This allows you to choose your user control and then be able to use it as a datatype for your property on your document type.
timepicker control in .net for using umbraco 4.7.1?
i want to create only timepicker control in .net for using umbraco 4.7.1?how can achieve this one?
Hi Siva
Hope this helps.
