  • Tom Maton 387 posts 660 karma points
    Mar 28, 2013 @ 00:16
    Tom Maton
    URL re-writing remove /home from all URL's
    Hi all,
    Apologise of which is probably a very simple question but I've not used Umbraco in over a year and getting back into now.
    I have a site with the following structure
    Content
    -- Home (GB) - global settings
    ---- Homepage - domain.com/homepage --> this is sorted with a rewrite (see below)
    ------ Content Page 1 - domain.com/homepage/content-page-1
    ------ Content Page 2 - domain.com/homepage/content-page-2
    I want to be able to have the content pages set as domain.com/content-page-2 without the need of setting up a url alias for each url, this wouldn't be easy to manage after a while.
    Below is what I currently have in my rewrite rules
    <add name="home"
        virtualUrl= "^~/homepage$"
        rewriteUrlParameter="ExcludeFromClientQueryString"
        destinationUrl="~/"
        ignoreCase="true"
        redirect="Application"
        redirectMode="Permanent" />
    Thanks in advance
    Tom
  • gary 385 posts 916 karma points
    Mar 28, 2013 @ 20:36
    gary
    Hi Tom
    Guess this is one of those . . .  .
    The top node of Umbraco is the domain regardless of what you call it, so it will not appear in the url.
    If you do not intend to have any content on that top node, re-direct as per this post.
    http://cultiv.nl/blog/2010/12/19/tip-of-the-week-the-ultimate-site-structure-setup/
    If you need other languages set them under right-click manage hostnames on the top node of each language, re-direct as required, if needed.
    Can hear you saying . . . . I knew that!
    Hope it helps
    G
    Apr 06, 2013 @ 16:49
    Tom Maton
    Sorry for late reply,
    This is the post that I got the idea from and copied the idea but have run into this problem.
    I dare say I've missed something simple, but gone through it 3 times to ensure Idone it correct.
    Tom
    Apr 06, 2013 @ 16:56
    gary
    Hi Tom
    Just looked at it again and realised what you have done.
    You have set contentPage1 and contentPage2 as children of homepage, therefore you will get homepage in the url.
    Set the document types as children of content and it will disappear from the url.
    If you are using latest versions of Umbraco, look on docType structure tab for "allow at root" at the top, you need to check this control.
    Sorry if I had looked harder, may have seen it sooner.
    Content
    -Home
    --Homepage
    -ContentPage 1
    -ContentPage 2
    So contentPage 1 and 2 are same "level" as Homepage
    Hope it helps
    G
    Apr 06, 2013 @ 18:06
    Tom Maton
    DOH!!!
    Thats spot on, thanks Gary.
