Try modifying you web.config so you set the customErrors mode to "Off" instead of remoteonly, which it currently is. By doing so we get a better error description. When you have done so please post the error message in here.
The current httpContext can only be set once during a request.
Exception Details: System.ApplicationException: The current httpContext can only be set once during a request.
Source Error:
Stack Trace:
[ApplicationException: The current httpContext can only be set once during a request.]
Umbraco.Web.UmbracoContext.set_Current(UmbracoContext value) +271
Umbraco.Web.UmbracoContext.EnsureContext(HttpContextBase httpContext, ApplicationContext applicationContext, Boolean replaceContext) +268
Umbraco.Web.UmbracoModule.BeginRequest(HttpContextBase httpContext) +160
Umbraco.Web.UmbracoModule.<Init>b__6(Object sender, EventArgs e) +80
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.17929
Trouble importing images
I am using Umbraco 6.03 and trying to import media. When I select 'Choose' i get a
Server Error in '/' Application
Can anyone help me? Thanks
Hi Lee
Doesn't make any sense to me, but here goes:
Source Error:
Hi Lee
Is this a fresh installation of Umbraco 6.0.3? And what database are you running?
