  • Dallas 133 posts 405 karma points
    Mar 30, 2013 @ 20:08
    Dallas
    Partial View Macros in 4.11
    Are Partial View Macros supported in 4.11.?
    The Macro editor screen has an entry for them, but it doesn't seem to work. It doesn't list the files in the partials folder, and if you manually enter a file it is saved as a script file.
    Is there a work around to use a Partial View Macro?
    Mar 30, 2013 @ 20:25
    Hi Dallas
    Are you running MVC mode or webforms mode?
    Mar 31, 2013 @ 00:41
    Dallas
    Jan, the site is running in MVC mode.
    Mar 31, 2013 @ 11:12
    Hi Dallas
    Ok, then I think it should display just fine. What is the exact 4.11 version you're using? I'm thinking wheter it's 4.11.3 for instance.
    Have you double checked that permisions have been set correctly? Do you see any errors messages in the browser console when trying to see them?
    Looking forward to hearing from you.
  • Charles Afford 1163 posts 1709 karma points
    Apr 01, 2013 @ 12:44
    Charles Afford
    Hi, i might have the wrong thing here, but i am using 4.11.4 and it works for me?
    In the macros folder i have my partial views.  If i click on one i can see
    Name
    Alias
    Use MVC Partial View -- From the drop down i can choose the files located at ~/Views/MacroPartials.
    (I am creating my partials and views in visual studio by opening the my wwwroot soloution as a website :).
    Hope this helps :).  Charlie.
  • Matt Brailsford 4125 posts 22223 karma points MVP 9x c-trib
    Apr 01, 2013 @ 12:54
    Matt Brailsford
    Hi Dallas,
    It should work, but I'm guessing, based on this line in your questions "It doesn't list the files in the partials folder", you may be getting confused with Partials and MacroPartials.
    Partials inherit from Umbraco.Web.Mvc.UmbracoTemplatePage and are located in ~/Views/Partials. Macro partials on the other hand inherit from Umbraco.Web.Macros.PartialViewMacroPage and are located in ~/Views/MacroPartials. If you want to create a macro partial, then you'll need to make sure you are using the later method.
    Hope that helps
    Matt
    Apr 04, 2013 @ 17:04
    Dallas
    Thanks all for confirming that MacroPartials do work. Matt, you are correct I had confused Partials and MacroPartials. I was thinking of Macro Partials as being normal partials that are chosen as a Macro.
    The MacroPartials folder should have been an obvious clue! However I will add that the Macro edit screen label is 'Use MVC Partial View', and the dropdown label is 'Browse partial view files on server..'
    Dallas
    Apr 04, 2013 @ 17:06
    Dallas
    Matt, I accidentally clicked the 'solved' icon on my response and not your answer. Is there a way to change that?
    Apr 04, 2013 @ 17:07
    Matt Brailsford
    Hey Dallas,
    lol, not without asking HQ to fix it :)
    Don't worry about it, enjoy the karma and glad you got it working.
    Matt
