For a client i want to rename the /umbraco/ admin folder to something different, say "admin" in this example.
I make two changes in the web.config for this to work:
<add key="umbracoReservedPaths" value="/umbraco/,/admin/" /> <add key="umbracoPath" value="/umbraco" />
For some reason after i do this, the context menu (rightclicking anything in the tree-structure on the left had side) no longer works in Firefox (it does in IE). The popup dialog appears for a brief moment and then dissepears...
all help is very much appreciated!
I also ran into issues when I tried to rename the backoffice folder.
Have a look at this post by Tim: http://blogs.thesitedoctor.co.uk/tim/2009/04/28/Fix+Missing+JavaScript+File+When+You+Rename+The+Umbraco+Admin+Directory.aspx It has to do with loading the xloadtree.js file.
Tim came up with a rewrite rule, which makes sense. I did some testing myself, but I didn't get it to work unfortunately.
Thanks! that rewrite rule did the trick!
The lines i added to urlrewriting.config are:
<add name="missingjs" virtualUrl="^~/path-to-admin-directory_client/ui/(.*).js" rewriteUrlParameter="ExcludeFromClientQueryString" destinationUrl="~/umbraco_client/ui/$1.js" ignoreCase="true" />
right-click (context) menu's stop working in backend when i adjust the backend path?
