  • Anders Holmér 20 posts 41 karma points
    Sep 07, 2009 @ 17:00
    Anders Holmér
    Trying to use word 2007 on Umbraco 4
    Hello
    I try to use Word as my editor for Umbraco 4.0.2.1 installed on IIS7, it works great running on a IIS6 installation.
    The only response i got from word is "can not publish the document, provider is not available", I got a 200 entry in the iis logfile
    2009-09-07 13:59:20 172.16.1.20 POST /umbraco/channels.aspx - 80 - 172.16.1.20 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+6.0;+WOW64;+SLCC1;+.NET+CLR+2.0.50727;+.NET+CLR+3.5.21022;+InfoPath.2;+.NET+CLR+3.5.30729;+.NET+CLR+3.0.30618) 200 0 0 31
    2009-09-07 13:59:29 172.16.1.20 POST /umbraco/channels.aspx - 80 - 172.16.1.20 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+6.0;+WOW64;+SLCC1;+.NET+CLR+2.0.50727;+.NET+CLR+3.5.21022;+InfoPath.2;+.NET+CLR+3.5.30729;+.NET+CLR+3.0.30618) 200 0 0 31
    I have searched through the forums but have not found any solution for this problem on IIS7, is there anybody who reconize this problem?
    running on:
    Umbraco 4.0.2.1
    Windows Small Business Server 2008 (IIS7)
    asp.net 3.5 config
    Word 2007
    regards
    Anders
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Sep 07, 2009 @ 17:19
    Douglas Robar
    Haven't had that problem, but there are a few things to try...
    First, be sure to use the Word-specific url (/umbraco/channels/work.aspx). Shouldn't make much difference but it is there for a reason.
    Second, test that the webservice is responding properly by using your browser and visiting http://localhost/umbraco/channels/word.aspx You should get back a list of webservice functions. If not, the problem is in the umbraco/iis setup. If you do get a typical webservice response page then the problem is in your Word configuration.
    Let us know what you find out and we can help you further.
    cheers,
    doug.
    Sep 07, 2009 @ 18:05
    Anders Holmér
    Thanks for the quick reply
    When I looked closer at the settings in umbraco, I saw that I had chosen the wrong field into the channel, I had chosen "Content" as a field instead of "Body Text"
    Thanks for your help
    Sep 07, 2009 @ 21:12
    Anders Holmér
    More info...
    I looked further and it turned out that you can not use "Classic .NET AppPool" as Application pool, Managed Pipeline Mode has to be Integrated, I created a new one and then i works fine.
    /Anders
