This one was a while ago and if I remember rightly we had a rewrite rule which changed the casing for all URLs. The request URL was case sensitive so we removed that.
Thank's for your quick reply. Well I do not have that kind of URL rewriting, so I have to continue searching for a solution... I'ts strange because it works on my local computer, but not on the server.
I too had the same issue with the media page constantly loading (spinning icon in right hand panel). Including the following exceptions to my lowercase rewrite rule fixed this issue.
Media Preview - /base/folderbrowserservice/getchildren/ - /base/folderbrowserservice/getchildren/
I've just upgraded a site to 4.11.6 but now the Media section isn't working correctly.
I'm sure this was fixed at one point??
When I look at the error I see the error is at /base/folderbrowserservice/getchildren/1094/?_=1365686633833
and the error message is
<error>Extension or method not found.</error>
Fixed it. Was a silly internal rewrite rule which was affecting the request!
I've got the same problem after upgrading from 4.8.0 to 4.11.10. Ben, could you elaborate a bit about your solution? What rewrite rule did you fix?
Hi Patrik,
Hi Ben,
Do you find the solution.. Its happening for us also on a 4.11.10 site..
There is no URL rewrites and the URL /base/FolderBrowserService/GetChildren/1160?_=1377115837768
shows <error>Extension not found or permission denied</error>
Yes, I finally found my problem. I had to change the IIS ASP.NET mode from Classic to Integrated.
<conditions logicalGrouping="MatchAll" trackAllCaptures="false">
<add input="{URL}" pattern="Umbraco/(.*)" negate="true" />
<add input="{URL}" pattern="base/(.*)" negate="true" />
etc...
Just as a note for other people running in to this:
If you get this error after you've upgraded from an older version of Umbraco make sure that your replace the Umbraco Module in the web.config;
In < httpModules>:
Replace those three with:
(note that this one has the space before "UmbracoModule" removed, something we later fixed in v6).
And in < modules> remove:
Replace with:
