I'm packaging up a new project I'm about to release but for some reason the Views I've added to the package show up blank wehn it's installed onto a test environment, I'm wondering why this is happening and how I can resolve it.
For example I have a new called 'Main', I add this to my new package, save and publish then download it and then install the downloaded package onto my test environment, the package installs successfully and adds 'Main' to the templates but instead of having a full website page inside it, it has the default View content as below:
Instead of selecting templates only, I selected the files specifically and that seemed to work, feels a bit hacky though since it says when you select a template its file is automatically added.
Packaging MVC Views
Any help would be appreciated and thank you in advance,
Luke
