  • Craig100 1136 posts 2523 karma points c-trib
    Apr 29, 2013 @ 14:18
    Craig100
    The Cogworks - Cookie Directive
    Just installed The Cogworks - Cookie Directive v1.0 as a quick fix in a V6.0.3 site.  All working well apart from the Cookie Refresher. When operated it gives a YSOD:-
       umbraco.cms.businesslogic.web.Document.get_Text() +12
       TheCogworksCookieDirective.Web.usercontrols.TheCogworksCookieDirective.<>c__DisplayClass7.<EnsureUmbContentFromRequestCookies>b__4(Document x) +43
       System.Linq.Enumerable.FirstOrDefault(IEnumerable`1 source, Func`2 predicate) +153
       TheCogworksCookieDirective.Web.usercontrols.TheCogworksCookieDirective.CookieRefresher.EnsureUmbContentFromRequestCookies(IEnumerable`1 cookiesNodes) +817
       TheCogworksCookieDirective.Web.usercontrols.TheCogworksCookieDirective.CookieRefresher.BtnRefresh_Click(Object sender, EventArgs e) +269
       System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
       System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
       System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
    I'm pretty sure I haven't missed anything from the set up video: http://www.screenr.com/wgF8
    Does anyone have any clue as to what might be wrong?
    Craig
  • Kristoffer Eriksen 185 posts 465 karma points
    May 24, 2013 @ 11:51
    Kristoffer Eriksen
    Did this got solved??
    I have the same problem. V6.0.5
    May 24, 2013 @ 12:10
    Craig100
    Not as far as I know. It came up just as the security issues arose a couple of weeks ago so maybe it's been forgotten about in the melee. Might be worth another Tweet.
