  • Kate 267 posts 610 karma points
    May 02, 2013 @ 10:02
    Kate
    How to patch my installation
    I have a quick question - just to make sure I do things right :-)
    I have a site running in 4.5.2 and I got the security patch for that version. The patch contains 4 items:
    umbraco.dll
    umbraco.pdb
    umbraco.webservices.dll
    umbraco.webservices.pdb
    In the 4.5.2 version there isen´t any umbraco.webservices.dll in the standard. So what do I do with that file ind the patch. Do I install it or not?
    And what about the .pdb files. What are they? should they be installed to?
    As you can see I have no idea what im doing, so I hope you can help :-)
    /Kate
    Sorry, maybe I should have mentioned that the patch im taking about is this one:
    http://umbraco.com/follow-us/blog-archive/2013/5/1/security-update-two-major-vulnerabilities-found
    May 02, 2013 @ 20:07
    Rich Green
    Hey Kate,
    You can just copy over the umbraco.dll file.
    Rich
    May 03, 2013 @ 09:48
    Kate
    Thanks Rich
    Just to be sure: I don´t need the umbraco.webservices.dll at all then?
    And another question. I have an umbraco running on version 4.11.6 but I cant find any patch for it. Is it because it dont need it or ?
