  • hssdev 5 posts 25 karma points
    May 04, 2013 @ 20:34
    hssdev
    creating a url prefix
    Hi there,
    I made a site in umbraco many years ago (4.0.4.1 version) and I have a content node under /members/kickboxer which generates urlhttp://.../ikckboxer.aspx and then i have a different doc type for news stories.  I have made a news story news/kickboxer which also generates the same url as the first example and show the content of the member and not the news story.
    How can i create a url prefix so that /members/kickboxer.aspx is different than /news/kickboxer.aspx, any info gratefully received :)
    Also, get message when log in to upgrade to version 6, is this a relatively painless process or not?
    May 05, 2013 @ 19:13
    Tom Fulton
    If you place your top-level nodes under a Homepage node, this should happen automatically.  So like this:
    Content
      Home
        News
          Kickboxer
        Members
          Kickboxer
    You'll automatically get /news/kickboer.aspx and /members/kickboxer.aspx as Umbraco ignores the top-level nodes from the URL path.  You might also be able to disable it by changing the `umbracoHideTopLevelNodeFromPath` setting in your web.config file.
    RE: Upgrading - You're on a pretty old Umbraco version, so my biggest concern would be compatibility with any packages you are using.  Do you have a lot?  To upgrade I'd recommend going to 4.5, then 4.7.2 or 4.8.1, then to the latest 4.11.x
    -Tom
