Does a node named "moneyless" exist in your content tree in Umbraco? If not that's the reason why you get a 404 error when trying to visit it.
You could make a 301 redirect when entering the "moneyless" page in the browser so it redirects to money-less.aspx - However this will not make any sense unless "moneyless" is referenced from other websites and for some reason appears in search results, or is referenced from printed material etc.
"Moneyless" is a reserved keywords?
Strange problem:
http://www.laboratorio21.com/artisti/money-less.aspx
work perfect. But the page renamed
http://www.laboratorio21.com/artisti/moneyless.aspx
return "404 error". Why?
Hi Gionata
Hope this makes sense.
Yes, obviously. I tried also with Preview button. And the path in tab Properties is correct.
1. If the page name is "Money less" the link is http://www.laboratorio21.com/it/artisti/money-less.aspx and run perfect.
2. If the page name is "Moneyless" the link is http://www.laboratorio21.com/it/artisti/moneyless.aspx and NOT run!
Thanks!
Hi Gionata
Ok, have you checked to see if someone has made this a reserved path in the web.config file then?
