  • Pete 213 posts 285 karma points
    May 09, 2013 @ 13:41
    Pete
    Member Properties confusion
    I'm creating members manually using the api.
    But I've noticed that I'm unable to set the Text Name of a member.
    I can set the LoginName and Email no problems.
    Is the "Name" field you see on the member properties page an actual settable field? or is it just a repeat of LoginName ?
    //create a member
    System.Web.Security.Membership.CreateUser(member_emailname.Trim(), password, member_emailname.Trim());
    System.Web.Security.Roles.AddUserToRole(member_emailname.Trim(), foldername);
    var member = System.Web.Security.Membership.GetUser(member_emailname.Trim());
    Member m = Member.GetMemberFromLoginName(member_emailname.Trim());
    //set a property value on the member
    m.LoginName = member_emailname.Trim();
    m.SetProperty("Name", member_name); // Doesn't seem to work
    m.SetProperty("Text", member_name); // Doesn't seem to work
    m.Save();
  • Barry Fogarty 493 posts 1129 karma points
    May 09, 2013 @ 14:12
    Barry Fogarty
    Hi Pete,
    Try this:
    m.Text = member_name;
    May 09, 2013 @ 14:39
    Pete
    Ha, thanks barry, could have sworn I tried that.
    Pete
