  • Streety 358 posts 568 karma points
    May 14, 2013 @ 16:28
    Streety
    GB Umbraco showing Portuguese Language
    Odd problem this.
    I am testing a new cloud server company called Luna Cloud. I have a Windows Server in English (had to change the locales etc) which works great, however the date and time stamps and login boxes are now showiing in Portuguese.
    I have changed everyting to UK and rebooted.
    In IIS Set UI culture to English
    Didn't help
    Must be an Umbraco Setting?
    Any ideas?
  • Charles Afford 1163 posts 1709 karma points
    May 14, 2013 @ 23:04
    Charles Afford
    have you tried the setting tab, the is a Languages Node in there that specifies the language.  That might be the problem.  :)  Charlie :)
    May 15, 2013 @ 10:17
    Streety
    Shows UK and US
    Its like its getting the value from the OS (which was set incorrectly)
    Is there anywhere else the locale is configured?
    May 15, 2013 @ 15:50
    Charles Afford
    Thats the only place i could think of.  Was it istanlled in English?  May be try one of the core team or try tweeting the question with  #umbraco :)
  • gary 385 posts 916 karma points
    May 17, 2013 @ 01:22
    gary
    hi Streety
    thought i might try to help with this one as i speak portuguese.
    Firstly one of the founders is portuguese, the main office is central london, but would suggest fhe servers are housed in Portugal as it is probably a tad cheaper than london.
    To this end, i would suggest that there is where the solution to the problem lies, its a strange one but as lisbon is on GMT, same as london, it may need a tweak on that to display in english rather than portuguese. Both settings are gmt +0.00
    hope this helps, if i can do anymore please let.me know.
    best regards and boa sorte
    gary
    May 17, 2013 @ 11:10
    Streety
    This doesn't make a much sense to me.
    I developed and Umbraco site in English hosted on a server in England which has been up and running for 3 years.
    I move to a Portugese hosting facility and now the base language has changed to Portuguese.
    Doh!
    Are there locale files in Umbraco?
    Something has screwed up.
    May 17, 2013 @ 11:45
    Streety
    Problem fixed.
    It was nothing to do with Umbraco.
    The locales in IIS were incorrectly set to Portuguese which I had done but didn't flush the APP_POOL.
    Showing as English now.
    DOH on me.
    Thanks for the responses.
