  • Dino 6 posts 28 karma points
    May 14, 2013 @ 18:07
    Dino
    Accessing query string parameters whilst entering content
    Our users want to be able to add query parameters from the current request as content in the page
    eg
    <a href="http://www.someSite.com/index.aspx?policynumber=[Insert Query String Value Here from request]">
    could they do something like this?
    <a href="http://www.someSite.com/[email protected]["policynumber"]">
    or is there a package that helps with this?
    or do I have to write my own macro?
  • Fuji Kusaka 2203 posts 4220 karma points
    May 14, 2013 @ 20:31
    Fuji Kusaka
    Hi Dino,
    You can add a textString property to your document type where you will insert the policyNumber .
    <a href="htp://www.somesite.com/[email protected]">
    if needed you can make some check for the query as well
    var policy = Request.QueryString["policynumber"];
  • Charles Afford 1163 posts 1709 karma points
    May 14, 2013 @ 21:53
    Charles Afford
    is it a internal system?  That sounds a bit risky :/
