  • shine 43 posts 83 karma points
    May 16, 2013 @ 08:50
    shine
    How we can use starts with and end ends with in xslt?
    here is my xslt
    <xsl:for-each select="$currentPage/ancestor-or-self::SiteRoot/SEGWThreeTextCol/ImageGallery">
                 <img style="width: 914px;" >
                <xsl:attribute name="src">
                 <xsl:value-of select="image"/>
               </xsl:attribute>
             </img>
        </xsl:for-each>
    which generate the path like /media/4578/1.jpg
    i want to remove the media folder in my path and want to replace '/' tag to '\/' that means
    i want to path \/4578\/1.jpg using starts with and ends with function for my above xslt
    May 16, 2013 @ 18:31
    Hi Shine
    What is your reason for wanting to do so? By removing "media" you ruin the path for the image and you will get a broken image in your browser instead? Perhaps some redirection stuff can be done but I'm not sure I'm getting the point of doing so?
