I'm trying to modify my site razor template to add breadcrumbs navigation. I tried using this snippet http://our.umbraco.org/wiki/reference/code-snippets/razor-snippets/breadcrumb
but that doesn't work with umbraco 6 (objects must be called something different in the new core). Much appreciate any info pointing me in the right direction.
I think you'll have better luck asking in the razor section:
http://our.umbraco.org/forum/developers/razor
thanks, I re-posted in the proper forum
Upload image
razor syntax for breadcrumb in umbraco 6
