I keep getting the following error appear in the umbracoLog table;
Error loading IApplication:
System.Reflection.TargetInvocationException: Exception has been thrown
by the target of an invocation. ---> System.TypeLoadException: Could
not load type 'umbraco.presentation.masterpages.MasterPageLoadHandler'
from assembly 'umbraco, Version=1.0.3441.17657, Culture=neutral,
PublicKeyToken=null'.
at Umbraco.Concierge.Businesslogic.application..ctor()
--- End of inner exception stack trace ---
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type,
Boolean publicOnly, Boolean noCheck, Boolean& canBeCached,
RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)
at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at umbraco.BusinessLogic.Application.RegisterIApplications()
The site is all working fine and I can't find any obvious issues, Does anyone have any pointers for me on what I can do to resolve it?
Also having problems with media and content pickers with the following error in the umbracoLog table;
At
/umbraco/tree.aspx?rnd=fd4631b4-9dc6-477c-ad24-eaefb31f6442&id=-1&treeType=media&contextMenu=false&isDialog=true&dialogMode=id
(Referred by:
http://www.esc.nsw.gov.au/umbraco/TreeInit.aspx?app=media&isDialog=true&dialogMode=id&contextMenu=false&functionToCall=parent.dialogHandler):
System.NullReferenceException: Object reference not set to an instance
of an object.
at Umbraco.Concierge.LockUnLock.Events.TreeEvent.a(XmlTree& b, XmlTreeNode& b, EventArgs b)
at
umbraco.cms.presentation.Trees.BaseTree.BeforeNodeRenderEventHandler.Invoke(XmlTree&
sender, XmlTreeNode& node, EventArgs e)
at umbraco.cms.presentation.Trees.BaseTree.OnBeforeNodeRender(XmlTree& sender, XmlTreeNode& node, EventArgs e)
at umbraco.loadMedia.Render(XmlTree& tree)
at umbraco.cms.presentation.tree.LoadTree(String treeAlias)
at umbraco.cms.presentation.tree.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at umbraco.BasePages.BasePage.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
It seems to have started since installing the new version of Concierge and if I remove Concierge the Pickers start working again.
Hi All
Error loading IApplication: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeLoadException: Could not load type 'umbraco.presentation.masterpages.MasterPageLoadHandler' from assembly 'umbraco, Version=1.0.3441.17657, Culture=neutral, PublicKeyToken=null'.at Umbraco.Concierge.Businesslogic.application..ctor()
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
Cheers
Evan
At /umbraco/tree.aspx?rnd=fd4631b4-9dc6-477c-ad24-eaefb31f6442&id=-1&treeType=media&contextMenu=false&isDialog=true&dialogMode=id (Referred by: http://www.esc.nsw.gov.au/umbraco/TreeInit.aspx?app=media&isDialog=true&dialogMode=id&contextMenu=false&functionToCall=parent.dialogHandler): System.NullReferenceException: Object reference not set to an instance of an object.at Umbraco.Concierge.LockUnLock.Events.TreeEvent.a(XmlTree& b, XmlTreeNode& b, EventArgs b)
at umbraco.cms.presentation.Trees.BaseTree.BeforeNodeRenderEventHandler.Invoke(XmlTree& sender, XmlTreeNode& node, EventArgs e)
I'm thinking that the errors may be related?
Cheers
Evan
