  • Davide Oliva 35 posts 199 karma points
    May 25, 2013 @ 08:57
    Davide Oliva
    form tags
    hi there, dear fellows.
    I would like to ask your advice about a trouble that I have in a website that uses umbraco 4.7.2.
    Currently the asp:LoginView control is shown in the header of the website, so the users can know if they are logged in and can logout from every page of the website, thus in the master template just below the <body> tag there is a tag <form runat="server">.
    The problem is: I would like to show also a search form in the header of website, but I can't because of the impossibility of nesting of form tag.
    Someone of you has an advice about solving this problem?
    I'm sorry for my english, I hope that this post can be clearly understandable.
    Thank you in advance and have a nice day.
    Davide
    May 25, 2013 @ 10:52
    Hi Davide
    The above question makes perfect sense.
    So the search that you want to implement will it also be based on a user control or do you wish to implement it using XSLT for instance?
    There are some different hacks/workarounds to make this work even though the code is wrapped inside the server form. So please let us know a bit more about how you want to implement the search function and then let's get into the details afterwards.
    May 27, 2013 @ 10:49
    Davide Oliva
    Hi Jan,
    We would like to use XSLTSearch, because of our needs which are rather limited.
    Do you have any suggestions for us?
    Thank you very much.
    Davide.
