  • Fergus Davidson 309 posts 588 karma points
    May 28, 2013 @ 18:26
    Fergus Davidson
    How to display the TinyMCE StatusBar
    i would like to be able to display the Tiny MCE status bar
    amongst other things, i have tried adding the theme_advanced_statusbar_location : "bottom" to the 'ValidElements' in the tinymce.config as per the post http://our.umbraco.org/forum/using/ui-questions/1870-tinymce-status-bar-option, but it is still not appearing.
    Any ideas?
    May 28, 2013 @ 21:40
    Hi Fergus
    What version of Umbraco are you using? And have you tried recycling the app pool or touching the web.config file after you made the change?
    May 28, 2013 @ 21:42
    Fergus Davidson
    hi Jan, thanks for your response.
    i am using 4.7.2 with no option of upgrade.
    yes, i touched the web.config - no joy
  • Mike Chambers 636 posts 1253 karma points c-trib
    May 30, 2013 @ 11:16
    Mike Chambers
    for v4+ same in the tinyMCEconfig.config add
    <config key="theme_umbraco_statusbar_location">bottom</config>
    May 30, 2013 @ 11:22
    Fergus Davidson
    Mike
    perfect! i am sure i tried that and was getting an error of 'duplicate key'. perhaps i was using a different key, who knows?
    the advice in the link above must be for an earlier version of TinyMCE
    Thank you
  • Antony Briggs 78 posts 103 karma points
    Apr 23, 2014 @ 15:11
    Antony Briggs
    3
    If anyone is looking how to do this in Umbraco 7, it appears that TinyMCE has been upgraded to V4 so you add the following to tinyMCEconfig.config
            <config key="statusbar">true</config>
    How this saves someone else 2hrs of googling :)
  • Jamie Attwood 210 posts 508 karma points c-trib
    Sep 27, 2016 @ 15:36
    Jamie Attwood
    Amazing thank you!
    This solves a lot of requests that people ask about the RTE to be able to select containing tags to apply classes. For example, apply a class to an li inside a ul from the list of formats, etc.
    This should be turned on by default.
    There is a lot of user frustration when people apply formats incorrectly and then are unable to apply them.
    Jamie
