We installed Umbraco 4.9.1 on our server as a subfolder of a main folder with a web.config folder in it. It's structure is kind of like this.
'mainFolder' with a web.config file, a bin folder, etc. --> 'Umbraco Install'
We have full permissions with Network Service on our install. We have not had this issue before because we have always installed Umbraco as our main folder and never as a subfolder.
For some reason it seems like it goes through the install process, I look in the "Installed Packages" folder in the Umbraco admin panel and the package file is there, but none of the other files have been installed. What could be the issues? Is there a conflict with having a web.config and bin files and folder in the parent folder? I would think that it would just put the files in the folder it needs to. I check the parent folders and none of the package's files are in those folders. So confused.
Packages not installing on our Umbraco install
