Forgive me if my terminology is incorrect, this is my first Umbraco site.
I have a document type named Company with attributes description, company_name, promo_code, and discount.
The companies are promoting a product on a podcast and I want to provide them a custom page URL like http://mysite.org/Umbraco and customize elements on standard pages specific to them. Each page would have various spots the company name would appear. Promo code will likely be the URL. Discount would be at certain parts of pages as well.
The non-ideal way would be creating multiple copies of each site. Any guidance or advice?
Assuming that the layout of each page would be exactly the same except that it would display different company infromation.
If this is the case then you create a template which would define the layout for your Company page. Insert your doc type properties as umbraco fields into your template.
Then you would create a different Content page (based on the Company Document type) for each company. Each content page will allow you to edit the details for that company.
Your content structure in umbraco would look like this
You are correct in your understanding. My prototype is exactly how you described it. The part that I am stuck at is concerning if each of those pages have multiple pages for filling information. So for one company would be
Content
Home
Company1
Basic Info
Optional Info
Payment
So each company would have the exact same sub pages with the doctype details reflected. Would you advise to just create the templates for those pages and each time I need to add a new company or maybe just implement those pages individually for each company. Since each page is based off a template I will be able to change the layout to affect all of them so that makes sense.
I can change the structure based on your advice Jules. This is how mine is currently. Should I just move the pages underneath each of the companies?
Content Home Company1 Basic Info Optional Info Payment Company2 Basic Info Optional Info Payment Company3 etc...
There will be a document type for BasicInfo, OptionalInfo and Payment and each of these document types will have a corresponding template (probably of the same name). If your Company page has a header (for example) that needs to appear also on the sub pages then you would set the BasicInfo, OptionalInfo and Payment templates to be child-templates of Company.
I have some further questions if you have the time.
Content Home Company1 Basic Info (Grabs property values from one under home) Optional Info (Grabs property values from one under home) Payment (Grabs property values from one under home) Company2 Basic Info (Grabs property values from one under home) Optional Info (Grabs property values from one under home) Payment (Grabs property values from one under home) Company3 etc... Basic Info (Where property values are set like content) Optional Info Payment
Basically I want to inherit the parent values so I only have to change it in one location. Can this be achived?
Custom referring to hand out
Content
Home
Company1
Company2
Company3
and each page would have urls as below
www.mysite.com/company1
www.mysite.com/company2
www.mysite.com/company3
Hope I have understood correctly
Jules
I would say that your content should be:
Content
Home
Company1
Basic Info
Optional Info
Payment
Company2
Basic Info
Optional Info
Payment
Company3
etc...
Your urls will look like this
www.mysite.com/company1/basic-info
www.mysite.com/company1/optional-info etc
I am guessing a bit at what you are trying to do but from what I can understand, this is how I would approach it.
Jules
Well done Jules. Thanks for taking the time to provide your assistance.
No problem :-)
Content
Home
Company1
Company2
Company3
etc...
Optional Info
Payment
