  • Michael Elsgaard 11 posts 28 karma points
    Jun 04, 2013 @ 09:53
    Michael Elsgaard
    Macro in editor
    If I insert a macro in the richtext editor I can't insert any text after it. The cursor just stays in the orange box.
    Furthermore I can't delete the macro. If I try, it's only the text inside the orange box that is deleted.
    I'm running Umbraco 6.1.1 and I've tested in both Chrome and Internet Explorer
    Anybody noticed the same issues?
    Thanks.
    Jun 04, 2013 @ 19:06
    Hi Michael
    Yes it can sometimes be rather difficult to add content if you started out by placing a macro in the editor.
    As a workaround you can Make sure to have some dummy text at the top and then hit enter som times and add some dummy text. Then place the macro between the two...it's not ideal at all. But it's a workaround. You could also add some breaks or paragraphs by entering the "HTML" editor mode. Not ideal either.
    I think this should actually be reported as a bug since it's rather annoying. If you file it is a bug please post the link in here so others can go and vote it up if they come across this post.
    Jan
