I´m not sure my question is in the right kategori - but I couldn´t find one that fit.Somone gave me the linkhttp://beta.umbraco.tv/videos/implementor/and I have a login to umbraco.com, but my problem is that this login doesn´t seem to work for this link (it does work for the normal umbraco.tv)Does anyone know if this is a error or I have to pay for yet another login to get acces to this part of the umbraco.tv?
Normally it should work. You can contact Tim Geyssens or Warren Buckley on twitter. They will help you out. There are still some glitches, it's still beta
@Jytte, get in touch through the support form http://beta.umbraco.tv/support/ (there are still some syncing issues between .com and the beta site but if you contact us we can fix it for you :) )
access to beta.umbraco.tv
Comment author was deleted
Thank you for your advise.
I´ve now posted my problem on the support form.
