  • suzyb 476 posts 934 karma points
    Jun 06, 2013 @ 20:06
    suzyb
    Error when editing stylesheet v6.0
    I've installed v6.0.6 but am getting an error when I try to edit a style.
    CS0103: The name 'UmbracoUser' does not exist in the current context
    Source Error:
    Line 11:         <tr>
    Line 12:           <th width="30%">
    Line 13:             <%=umbraco.ui.Text("name", UmbracoUser)%>:
    Line 14:           </th>
    Line 15:           <td class="propertyContent">
    Can anyone help fix this?
    Jun 06, 2013 @ 20:48
    Hi Suzyb
    Seems like a bug that should be reported in here http://issues.umbraco.org/issues/U4 - Please share the link to the bug report in here so others who come across this post can go and vote it up.
    Jan
  • philw 99 posts 434 karma points
    Jun 27, 2013 @ 20:03
    philw
    SAme issue here. Worked ok with earlier versions (6.05)
    Jun 29, 2013 @ 23:41
    Hi Guys
    Maybe this has been fixed with the release of 6.0.7 - could be worh trying to upgrade.
  • William Burnett 213 posts 262 karma points
    Jul 08, 2013 @ 16:28
    William Burnett
    Same issue here... and again, another "vote" to abandond the "vote it up" system, as it is clearly useless...
    Not only that, but I had to find this post via google search, as the intenral search did not yield relevant results in several attempts.
  • rich hamilton 117 posts 136 karma points
    Jul 09, 2013 @ 18:24
    rich hamilton
    Same problem
    Umbraco v6.0.6 (Assembly version: 1.0.4898.16909)
    Jul 09, 2013 @ 18:30
    rich hamilton
    Whats the easiest way to upgrade from 6.06 to latest version?
  • Scott Robinson 54 posts 75 karma points
    Jul 22, 2013 @ 11:41
    Scott Robinson
    Same issue for me on 6.0.6
    Is there any fix? I'd prefer not to upgrade at this time.
  • Proxicode 128 posts 324 karma points
    Jul 24, 2013 @ 23:20
    Proxicode
    If you are still on 6.0.6 and cannot or don't care to upgrade...I was able to work around this by going to \Umbraco\Settings\Stylesheet\Property\EditStyleSheetProperty.aspx file directly in a text editor and changing any instance of this line..
    %=umbraco.ui.Text("preview", UmbracoUser)%
    to this..
    %=umbraco.ui.Text("styles", base.getUser())%
    Hope this helps someone.
  • Mark Downie 8 posts 28 karma points
    Apr 01, 2014 @ 19:16
    Mark Downie
    Thank you Roger - this was very helpfull.
  • kleptbit 42 posts 98 karma points
    Mar 20, 2015 @ 13:32
    kleptbit
    Yes, thank you Roger, that worked a treat.
    Oh how I wish I could upgrade...
