I've editing some content (The Richtext editor is associated to a stylesheet so users can select classes from the 'style' dropdown). So for instance if I type the words 'Hello this is Craig' I would expect to the see the HTML render as....
<p>Hello this is Craig</p>
But what is atually being rendered is....
<p><span>Hello this is Craig</span></p>
And I've no idea where this span is coming from!!! It's not in the stylesheet anywhere!
It wouldn't be such a biggie but it's stopping me from being able to apply classes to the content as I can't target areas of content correctly. For instance if I want to add a class to a link, it's actually adding the class that's wrapped around the link.
I just come accross the same problem, I'm using Umbraco 6.1.3 I have added screenshots:
Datatype:
HTML code:
Result in Chrome: Weird bug if you ask me :S
Just figured out that when you adjust the HTML of the richcontent editor you need to manually delete the <p> and <span>. But then when you click save it automaticly ads the <p> again!
The only thing that i noticed in my solution was that I'd associated the CSS to the rich text editor. So I removed this association and then the RTE stopped adding the <span> class. Give that a whirl.
Richtext Editor always add 'span' element
Hiya Folks,
Got a weird one (well I think it's weird!).
This one's driving me mad!!
Any ideas anyone??
Hi Craig,
That is a strange one. what version of Umbraco are you using? Also can you take some screenshots of how your rich text editor styles are defned?
Cheers
L
Datatype:
HTML code:
Craig
