  • Matt Taylor 873 posts 2086 karma points
    Jun 18, 2013 @ 09:57
    Matt Taylor
    How to require members to change their password on first use?
    If a new member has been craeted in the Umbraco UI I'd like to require the user to change their password when they first log in.
    A simple requirement but I'm not sure if there's the bits in place in either Umbraco or ASP.Net Membership to do it.
    Any ideas on how I would implement the facility?
    Regards,
    Matt
  • Alex Skrypnyk 6175 posts 24186 karma points MVP 8x admin c-trib
    Jun 18, 2013 @ 11:31
    Alex Skrypnyk
    Hi Matt,
    How new users can login to your site ?
    You can send eMail message with requirement to set password or something like that.
    Alex
    Jun 18, 2013 @ 11:49
    Matt Taylor
    Yes, we can create a new member in the UI.
    Send them an email with their username and password.
    Then we need to make sure they change it when the first log in, but what is a good method?
    Cheers, Matt
