Javascript crash in umbraco backend - json not defined ie7
Not sure if this is the right place to put this question but as it is related mainly to umbraco backend here goes:-
I'm using the ublogsy package which uses json objects for saving objects as IE7(browser client will be using) doesn't handle json I need to use something like douglas crockfords json2 js package where do I reference this so it is can be used by umbraco in the backend when I click the Save buttons?
Paul
Or in other words will I need access to the umbraco core to reference it?
