Does the "Remove At" property on the properties tab auto-magically unpublish content or is there some process I'm supposed to be running every day? I've set a remove at date for a node and it's still showing up on the site.
Thanks, Gracias, Danke vielmals, Tak!
It "should" work automatically. The method that should be doing the unpublish stuff is called every 10 minutes or so.
However I have seen issues mentioned about this before, so you may want to report at bug, if you can't get it to work.
How Does 'Remove At' Work?
