  • siva kumar 120 posts 209 karma points
    Jun 19, 2013 @ 07:44
    siva kumar
    datepicker not showing and unable to enter letters in texbox in umbraco 4.7.1.1?
    i created a simple control using jquery it is working but if i add another default jquery based datatype like datepicker, it is not showing the datepicker image.and also added textbox.i am not able to enter text if i try to enter the letters it is reloading  automatically how to  solve this?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jun 19, 2013 @ 12:26
    Jeroen Breuer
    Maybe your simple control is in conflict with datepicker datatype? If the datepicker doesn't work I think it only shows a textbox so it might be a good idea to check the console for errors.
    Jeroen
    Jun 19, 2013 @ 13:54
    siva kumar
    hi Jeroen,
    i  used the code  $.noConflict(); after that i called  jquery function (about datepicker) is there any issue with this?I found that there are 2 types of jquery versions in my umbraco backoffice.how to work with at  a time with these 2 versions?
