  • Bewar Maronsi 1 post 21 karma points
    Jun 20, 2013 @ 10:38
    Bewar Maronsi
    Multilanguage site, missing language and how to add new.
    Ive been searching the web for an answer to my question but i havent found anything yet, maybe im using the wrong keywords. The site that im making needs to have 3 sections, English, Arabic and Kurdish. The problem is that the Kurdish language cant be found in the cms where you add a new language to your site. So i want to know how i can add it manually. Ive been searching thru the files but there are so many. No luck so far.
    Any answer would be great and sorry if this question has been answered before.
    Thank you.
    Jun 20, 2013 @ 17:18
    Dave Woestenborghs
    I don't thinks it's possible to use Kurdish with Umbraco at the moment.
    The language create dropdown code can be found here : https://github.com/umbraco/Umbraco-CMS/blob/53b31a5c1b4f0bfc7048db5b4994f03e15cb8702/src/Umbraco.Web/umbraco.presentation/umbraco/create/language.ascx.cs
    As I look at that I see that neutral Cultures are filtered out.
