  • Mikael Mørup 297 posts 326 karma points
    Sep 20, 2009 @ 12:07
    Mikael Mørup
    TimyMCE tooltips
    Is it possible to change the tooltips shown when the mouse is over the buttons in the TinyMCE toolbar?
    I checked the TinyMCE config file and it doesent seem to hold the tooltip strings.
    Mikael
  • Thomas Höhler 1237 posts 1709 karma points MVP
    Sep 20, 2009 @ 13:09
    Thomas Höhler
    Take a look into the language js file in /umbraco_client/tinymce3/langs/
    hth, Thomas
    Sep 20, 2009 @ 14:05
    Mikael Mørup
    Thanks thomas
    In my case, it's the tooltip for the template plugin that i enabled. I found the language files for the plugin here:
    umbraco-client/tinymce3/plugins/template/langs
    But changing the string does not have any effect, the tooltip remains unaffected. I tred to tuch my web.config, and even to restart my (Windows Vista) computer.
    Sep 20, 2009 @ 17:59
    Thomas Höhler
    you have to clear yor browser cache i think
    Sep 21, 2009 @ 11:58
    Mikael Mørup
    Hmm, even with cache cleared it doesent seem to work.
    Mikael
    Oct 01, 2009 @ 14:00
    Thomas Höhler
    Just cleared the cache and changed something in umbraco_client\tinymce3\themes\umbraco\langs\de.js and this works. So the right path is: umbraco_client/tinymce3/themes/umbraco/langs/
    Thomas
    Oct 01, 2009 @ 22:47
    Mikael Mørup
    Hi Thomas
    Thanks for keeping this alive :-)
    My problem is that the lang file for the template plugin is not in that folder. It's in umbraco_client/tinymce3/plugins/template//langs/
    And i can find the text for the tool tip ("insert predefined contents") but changing it does not change it in the editor.
    It's really strange.
    Mikael
  • Elena 8 posts 29 karma points
    Oct 13, 2009 @ 23:25
    Elena
    What language do you use, Thomas used the german, so you should try the danish language file instead of the US/english. I've played around with my own russian translation and that worked very well
    Oct 14, 2009 @ 00:14
    Thomas Höhler
    Did you check/sync the files from your installation to the actual download of umbraco?
    Oct 14, 2009 @ 09:43
    Mikael Mørup
    I'll try that
    Oct 14, 2009 @ 10:35
    Dirk De Grave
    Not sure about this but an app restart may force those files to be reloaded!
    /Dirk
